.061 to .074 size to electric
Building a Mini Kaos and the plans call for a 061 to 074 engine. I'm going electric and need info for the correct size motor and ESC. Would a 370 and 18 amp be too much? I'm thinking it would be. I'm old school and have always used nitro. New to electrics. Battery most likely going to be a 3S 2200mA.
Skyhawk
Sandusky, OH
Skyhawk
Sandusky, OH
By choosing a smaller prop, a power system cannot be too much. You cannot overrev a motor with too small a prop.
Plane type and mass are leading when choosing a power system.
- Rules of thumb for electric power
Magic numbers for e-flight - WFF - Gibbs Guides
→ Articles
→ How to choose an electric power system - The Ampeer
→ E-book: Everything you wanted to know about electric powered flight
→ Chapter Sizing Power Systems for Electric Airplanes - How to choose a power system - RCG
- Beginners Guide to Motor and Prop Selection - RCG
- System power - RCG, several messages
- Several design papers
rcaeronotes.wordpress.com/design-and-analysis-notes
Not a specific answer for you, but in general ...
It is a good practice to have some headroom built in.
About derating motors, controllers, batteries, electronics in general:
- Derating, starting at ... Then there is the 75% rule of thumb ...
Questions and Answers.... - Page 928 - RCG - Motorcurrent is proportional to voltage squared, and proportional to Kv cubed.
A 10% change in battery voltage will give a 20% change in current, a 10% change in Kv will give a 30% increase. Not quite, because battery voltage will sag more due to higher current, but you'll get the idea. - extra current with one or two cells added, simple table
A.k.a. "Why did my motor and/or controller and/or battery go up in smoke ??? ¨.
In depth discussion
www.theampeer.org/ampeer/ampnov15/ampnov15.htm#ADD - About de-rating controllers and motors, starting at for everyone else:
Questions and Answers.... - Page 290 - RCG
Some well-structured reading for rainy/windy days, and some handy e-tools as well. Will save you, and us a lot of questions. Notably the 'what went wrong?' kind of questions Will also prevent you from burning up several controllers and/or motors and/or battery:
E-flight primer and tools
And pleasepleaseplease, do your RC equipment, wallet, ego, battery, controller, motor, house/garage/car a big favour ... get a watt-meter. It will more than pay for itself, will save you at least one fried motor and one fried controller. Will also help you finding optimal setup.
Without a watt-meter you are in the dark. Until something starts to glow
close out sale Hyperion Emeter II, with optical and electrical tach, servo tester, local&remote logging - RCG
Vriendelijke groeten Ron
