Gear box that fits Razor 350?
WI
Looking for a gear box that will fit the Razor 350, would like one that has several ratios to choose from, are there gear boxes that will work without a lot of modification?
flierbk
flierbk
RE: Gear box that fits Razor 350?
the gws 300 gb's are the easiest to use.
The motor is too small so use an o ring to support the motor can, they then bolt straight in.
lots of ratios to choose from
My Feedback: (8)
TN
Where is the best place to find gears for the razor 350?
I spun my 13 tooth bronze gear off and dont know what to ask
for is the shaft the same size as the gws motors?
My Feedback: (8)
TN
I just ordered a couple gears from Bishop Power
[email protected] they stock the Stainless Steel pinion gears $2.75 each
ORIGINAL: Dr Kiwi
Loctite 638 -green - is the strongest for rotational forces. Some people have had success with JB Weld.
Cheers, Phil
Cheers, Phil
TN
Here is one place to go for a Razor 350 gearbox - you can fit whatever GWS ratio spur and pinion you want into it. http://www.cl-i-max.com
You can also get a Won housing (search on RC Groups) - any GWS ratio you like with this one too. (here's a photo)
