Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Building a new plane...
Old 04-08-2004, 08:31 PM
Gizzmo0411
Default Building a new plane...
Hello all,
I've recently begun a plane of my own design but need all electronics...Here's what I've come up with:
This would run a 370 motor on a 4:1 gear with a 9X4.7 prop.
First of all...is this a good setup...
Second of all...could I get this same stuff (or it's equivalent) for cheaper anywhere else???
Old 04-08-2004, 08:58 PM
NMPhi767
NMPhi767's Avatar
Default RE: Building a new plane...
I noticed you are running a 3s li-po on a 370 motor. 11.1 volts is pretty high for a brushed motor. I would be concerned about burning it up. Also, if you are going to ever build other planes you might want to get a JR XF631 radio system or a JR XP6102 radio system. More expensive, but they are both computer radios, have six channels, and have memories for more than one model.
Old 04-08-2004, 10:21 PM
Gizzmo0411
Changed that...
Now I've got:
Same radio system as above with an extra servo
pico-20 ESC
2 cell 1200 mah lipo
8X6 prop
370 motor geared 4:1
How's that sound??
Old 04-08-2004, 11:37 PM
NMPhi767
NMPhi767's Avatar
Looks good. You could probably still get away with some more prop with that gearbox you are running. The battery will give you some pretty long flight times. Probably in the 15 minute range at full throttle and if you stay off the throttle you could probably extend it to 30 minutes.
Old 04-08-2004, 11:52 PM
Gizzmo0411
Yeah...I got two different props...1 9X7 and one 10X8 so I'll see what happens with that.
Old 04-09-2004, 07:46 AM
Blaster_Boy
Download Motocalc from their web site http://www.motocalc.com Use the 30 day trial, you can compute all the variables you are asking about with it. After your 30 days, if you want to keep it, it's $35.
Old 04-09-2004, 09:25 AM
Gizzmo0411
I've already used motocalc...but it doesn't help if I don't understand the theory behind it. What a gearbox does, what a prop pitch and and length means, that sort of stuff...however, now that I understand that stuff...motocalc is great.
