Increasing Visibility and Amateur Radio Frequencies
OH
First of here's a visibility question
My friends and I purchased Firebird Commanders to start in newbie combat, however these little white birds are hard to see! Whats a good way to brighten these foam winged planes?
Second HAM freqs.
I just got my ham license and I'd like to run an off frequency so I never have to worry about messing up someone elses bird at the field. Has anyone had any experience with 50Mhz transmitters/recievers?
Second HAM freqs.
UT
RE: Increasing Visibility and Amateur Radio Frequencies
Put some floresent red, paint or Monacote. Caution on the paint some will eat the foam.
Have flown on 50 & 53 for 25 years, works fine but all my buddies are there also. Selling a radio is a lot harder if it is on these frequencies as they can only be sold to another ham.
OH
bpannier - I'm a bit scared about spray paint, so I guess i'll have to get some low heat monokote.
Obviously you can't just switch the crystals out of a 27 or 72Mhz radio, so where can you pick up one in the 50Mhz range?
73 - KC8ZZZ
(last KC8 call!!!)
73 - KC8ZZZ
(last KC8 call!!!)
My Feedback: (21)
As he said, from another HAM, or you need to special order it. Any hobby shop should be able to do that for you, local or online.
My Feedback: (7)
ORIGINAL: bpannier
OH
I just came up with a little visibility rig.. i didn't have colored tape like Co Fly uses, but I did have an extra sticker pack from a Foam plane I bought at walmart. They're the perfect size for the wing and VERY BRIGHT!
UT
yOU ARE CORRECT ON NOT JUST CHANGING THE CRYSTAL. tHE RADIO MUST HAVE A NEW MODULE. THIS IS NOT THE CASE ON THE LOW END RADIOS AS THEY HAVE NO MODULE
VA
What radios are you guys talking about not being able to change the crystals on?
Every 27, 72, and 75mhz radio I have you can swap out the crystals. We do it all the time.
ORIGINAL: dockman2
My Feedback: (7)
ORIGINAL: Vulturetec
Between a 50/53Mhz radio and a 72Mhz radio. The receivers and antennas aren't designed to cover that broad a frequency shift. I've never looked into it, but I would think its possible to swap the RF-decks between a 50mhz transmitter and a 72mhz transmitter because the RF deck (module) should have all the critical components on it, leaving just the antenna as a question mark.
ORIGINAL: dockman2
Your mileage may vary!
My Feedback: (21)
ORIGINAL: dockman2
This is per the FCC's and AMA's interpretation of the FCC Part 95.
