Antenna inside or out ??
NJ
I noticed on their website that the Hobby Lobby guys were flying their P-51 without any of the antenna outside of the airplane. http://www.hobby-lobby.com/field_p51marie.htm
I like the cleaner lines, and was wondering if anyone else has flown with the antenna completely inside the plane and if they ever ran into any problems.
OR,
RE: Antenna inside or out ??
They are probably using a Lightenna mounted inside the fuse. There are a number of this type of antenna on the market. You simply cut off the stock antenna and solder the replacement on. Do a complete range check before flying.
http://www.hobby-lobby.com/antennas.htm
NJ
I wound up taking this recommendation. Works well.
http://www.darrolcady.com/Racing_Inf...ch/Antenna.htm
