GC Electra getting lighter?
I'm new at dry flying & my GB electre is too heavy. A friend suggests adding a speed control, 7th cell & micro servos. Any suggestions on what type of control & servos? I have a stock 400 motor with a folding prop. I tried a gear bx (wrong one) but it turned backwards. I was hoping to use a bigger prop with the bx set up.
My Feedback: (9)
I am still flying my CG Electra I built 10 years ago! This is the plane I tought myself to fly with.
This the setup I have had for several years now: Motor size 550, Master Airscrew or MP Jet gearbox with a 3.1 to 3.3 reduction ratio, 11x7 or 12/8 folding prop, 7 cells from 1200 mAh to 3000 mAh.
Do not worry about your servos, this plane does not need mini or micro servos, standard servos are OK. The key to good performance on this plane is the motor/gearbox/prop combination. The best way to reduce weight and improve performance is to use NiMH batteries instead of NiCd; you can save several ounces!
Enjoy,
Flying Cat
Enjoy,
Flying Cat
PA
When a gearbox is used the ESC connections (+and-) should be reversed at the motor. This reverses the motor rotation and results in the proper propellor rotation.
PA
Bernie,
If you have a "can" motor(one without adjustable brush timing),reversing polarity should no effect on the motor except some minor sparking until the brushes "wear in" in the new direction.
maurice
maurice
