Go Back  RCU Forums > Electric Aircraft Universe > Electric General Discussion
Reload this Page >
Stronger gears for Hitec HS 55?
Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Old 09-17-2004, 06:19 PM
scottm
Default Stronger gears for Hitec HS 55?
I am using HS 55's on a foamy parkflyer by insanefoamies.com. They work great except the geartrain is very delicate. A hard landing or even bumping the plane getting it out of the truck often results in a stripped gear tooth. It is always the gear that runs against the main output gear. In the last month it has probably happened 7-8 times. I get 1 free gear strip, because I can rotate the gear 180° for a fresh set of teeth. The next time it happens on that servo I have to use a new gear from the $5 replacement gear set. Does anyone know of an aftermarket HD gear set? Or how about an equivalent servo that is tougher?
Old 09-17-2004, 07:38 PM
Matt Kirsch
My Feedback: (21)
Matt Kirsch's Avatar
Default RE: Stronger gears for Hitec HS 55?
You're not using a large enough servo, plane (pun intended) and simple. If the servos strip that easily, one of these days it'll happen in flight. What is this park flyer you speak of?
I would replace the servos with HS81s or equivalent.
Old 09-18-2004, 09:57 AM
Foamaholic
Foamaholic's Avatar
Check here for metal gearsets.
http://servocity.com/html/servo_gearsets.html
Old 09-18-2004, 04:18 PM
Matt Kirsch
My Feedback: (21)
They don't make metal gearsets for the HS55 as far as I know.
Old 09-19-2004, 01:42 AM
rcelectfly
They now make a HS 56 that has stronger gears.
Chuck
Old 09-19-2004, 04:12 PM
scottm
Thanks guys. Foamaholic, there are no metal 55 gears on servo city. But I did discover the 56 HB, as rcelect said, which looks like the way to go.
http://servocity.com/html/hs-56hb_sub-micro.html
Matt, check out www.insanefoamies.com
I have the Edge 540 model. It is similar to other foamies out there, but the kit is very well-equipped and it flies great.
Old 09-20-2004, 12:22 PM
Greg Covey
Greg Covey's Avatar
The HS-56 is the way to go for a similar footprint with a stronger torque rating.
Keep in mind that the HS-56 servo arms and base are different sizes from the HS-55 but the case is similar in size.
Good luck!
Old 04-19-2011, 08:43 AM
Disarray
ORIGINAL: scottm
The OP mentions rotating the main gear 180 degrees and reusing it. How can that be done with the key on the shaft?
