repairing foam
repairing foam
I'm new to park flyers - my first is a GWS Pico Stick F. How do you repair damaged foam parts? (I'm taking some hits on the fuselage around the landing gear mount.) Thanks!
repairing foam
If you are talking about dents, I do not worry about them. I try to put packing tape were I think the abuse will be. If there are cracks, tears, broken parts I use white glue, probond, titebond or 5 minute epoxy.
Dru.
Dru.
repairing foam
if you can't find ProBond, use Gorilla Glue. I've used both, and with a good spritz of water on the glue and area to be patched, it dries much faster than ProBond (about 1/2 the time in my experience)
repairing foam
Most of the gws foam is hard even exposie to stick to maybe minwax polycyric couple coats then lit glass maybe like .7 lb type.
lots luck. Horizons hobbies sell wings and cheap. CU
