firebird rc equipment can i move it into another plane?
i recently bought a new firebird xl its actually a xxl golden eagle it has 3 channel controll but i was wondering if i bought a cpl of servos and receiver etc if the transmitter that is 27 mhz would still work them?.as everrything is on one board in this plane.thanks!
RE: firebird rc equipment can i move it into another plane?
i should have said i intend to use it in another plane !! to save buying another transmitter till i move onto the next level.
CA
I've been through about 7 firebird/aerobirds. generally the firebird stuff is all mounted to one board. the servos arent compatible with normal ones, the circuit board part of the servo is on the firebirds main board. also, the servos are usually programmed to permanantly run V-tail. Unless what you want to make is a v-tail with a body big enough to hold that board as is, Id toss the firebird guts and get a GWS flight pack.
