Mini Funtana Tailwheel?
My Feedback: (36)
IN
I'm in the process of building my Mini Funtana and as I set and stare at the tail "skid" I am thinking that a steerable tail "wheel" would be a better idea.
Anyone changing this on their MF?
What lite style tailwheel are you using?
Thanks!!
Munchee
Thanks!!
Munchee
VA
RE: Mini Funtana Tailwheel?
I've thought the same thing about the skid on the Mini Sportster that I'm using to teach my grandson to fly. It takes of and lands great, but once it reaches a certain speed on landing you loose all directional control of the tail. It would be nice if someone made a small version of the nylon tail wheel mounts used on larger plane.
Do you fly off grass or a paved runway? I use the stock skid and it is fine for grass. I doubt that a small tailwheel would do anything for me. I can still taxi off the runway, etc. You just need to use bursts of throttle to swing the tail around. On pavement, a wheel might help especially in crosswind situations. For takeoff, I point the nose up, hit the throttle and let go!! You definately want something light if you add something way back in the tail..
FC
FC
VA
Yes, that is the problem, it would have to be very light. I fly off pavement and while takeoffs are no problem, landings always turn one it reachs a certain speed. A tailwheel would help.
CA
Here is what I did. A 1/2" wheel some wire and other junk from the garage. I didn't weigh it but it can't be much.
Anybody want to give a tutorial on posting an image..................?
My Feedback: (45)
Look at the current issue of Model Aviation. There is an article that shows a tail wheel being added to a tiger electric. This might give you an idea or two. I am thinking about trying it on my Mini Funtana. When ever I get around to building it. Too many projects going at once.
I added a Micro Wattage brand steerable tailwheel to mine.........I love it! Now I can taxi down my driveway to the road and take off, then taxi home.......it's cool. Doesn't weigh much either, just make sure you mount it carefully......had to reinforce mine w/ Kevlar thread and thin super glue where you would use screws, since it broke right away. Now it's solid.
Scott
Scott
