Receiver Problems?? Help!!!
OH
I need help. I have a Hobbico Ventura and I had a crash. I had to replace the prop and spinner and made some minor repairs with clear tape to my wing. I thought that was all I needed. When I hook the battery up, the motor runs at full throttle with or without the transmitter on. Also, none of the flight contols respond when the transmitter is on. Has the transmitter been damaged? Could this be a problem with the ESC???
Please help. I am dying to get back up in the air...Thanks.
AR
RE: Receiver Problems?? Help!!!
Try turning your transmitter on first then then plugging in the battery. If this doesn't work then I would say look at the esc for problems.
dude... shouldn't the ESC have a safety??? ie only EVER runs if turned on with throttle in the OFF position!!?!?!??
OH
The answer to both questions is yes. I have turned on the transmitter first then connected the battery. Motor runs full throttle and none of the servos respond including the throttle.
Yes there is a safety switch that must be engaged prior to motor start, but this is not working either.
AR
Not all esc have safety switches. Usually the rtf like Hitec have safety switches but if you buy an esc the majority of the time they will need a switch put in line for a safety switch.
