How Much Exponential?
MI
The manual for my new Hitec Flash 5 suggests that most pilots use expo but doesn't give any recommendations. My Mini Super Sportster is very touchy without it (in the ailerons). At -10%, I couldn't tell the difference. -25% seemed better and -35% seemed like a bit too much. I know it's a personal thing but is there any general rule of thumb?
MI
RE: How Much Exponential?
You're right, it is a personal thing; if 20-30%doesn't do it, consider reducing the throw on your ailerons. You should be shooting for balanced controls, where aileron, elevator, and rudder all need similar amounts of stick movement for typical flying....Jim
My Feedback: (7)
I and a number of better flyers I know use 80% or even 100% exponential in channels 1,2, and 4. Some of my planes have slightly different rates by they are all on the high end.
Dick Dietz
Dick Dietz
TX
I have an Optic 6 and use 50% expo on both low rates and high rates and its my personal preference because I am comfortable with it and use to it.
MI
Thanks for weighing in, guys. I'm going to try ALL of your suggestions and see if I can find the "sweet" spot. This forum is invaluable...so many teachers...a real treasure chest.
Any other opinions?
Any other opinions?
TN
Yeah, I don't use expo at all! I tried it but found that it fools me into overcontrolling. I would move the stick a little, the plane would barely respond, so I would move the stick a little more and the plane would still not respond the way I want, so I would move the stick some more -- and of-course then it would respond way too much. Yes, I know it is just a matter of getting used to it -- but I do fine with my programmable dual rates, so...
