Best brand CA Super Glue for white foam?
NY
I picked up a bottle of CA "foam safe" gap filler super glue to repair my cessna. It cures in 30 seconds, but the glue is not holding the foam together. I used small amounts.
The bottle does not have a brand name on it, actually it has the name of my LHS on it, but there is a web address on the bottle that reads bsiadhesives.com.
What's the best foam safe CA? This stuff does not appear to be working well.
SAF
SAF
AZ
RE: Best brand CA Super Glue for white foam?
The BSI Adhesives are some of the best ones out right now for the hobbist. Its all I use for my ca glues and holds very well for me. You may have gotten a old bottle.
NY
Maybe I should go and speak with my LHS about it. I was under the impression CA bonds instantly, or at least within the stated cure time.
thanks,
SAF
thanks,
SAF
My Feedback: (-1)
I've had really great success with the black CA glue, sometimes called tire rubber CA. It's thick and goopy, hasn't eaten through any foam I've used it on so far and realy really really holds.
NY
ORIGINAL: Todd_J
SAF
