gws reciever bad??
gws reciever bad??
Hi All
I was doing some setup and testing on bench last night and when I went back today i recieved no response from motor though othe servos work fine swapped a diff reciever in and all was well
my ? is what did i do to fry reciever??
can you put too much voltage on a reciever
it is a gws mini reciever batt was a 3 cell kokam lipo2000 mah 15c rating
also can some one give me charging settings for a triton charger and this batt
currently 1.7 a 11.1 volt
TIA
Bansheeman
TIA
Bansheeman
My Feedback: (21)
RE: gws reciever bad??
One thing to keep in mind is that you didn't necessarily do anything wrong/bad/stupid to damage the receiver. Shtuff happens... If you can't find an obvious reason, and the replacement works okay, there's really no other explanation.
Charger settings:
1. LiPoly program.
2. Voltage = 11.1V, because the pack is a 3-cell.
3. Current = up to 2 Amps, because the pack is a 2000mAh pack
Charger settings:
1. LiPoly program.
Well I talked to GWS and they said 7.2 is max voltage for the reciever
I have asked them how then does this reciever find its way into a flight pack that comes with a 9.6 volt batt in it
no reply yet
i purchased another one and dont want to fry it as well
need help or suggestions
TIA
Doug
no reply yet
TIA
Doug
MD
The ESC regulates the voltage to the receiver and servos to 5V. Only the motor gets the full 11.1V, or whatever your pack is rated at. If you tried to somehow plug the battery directly into the receiver, you would definitely have "problems".
