Motor kit for OLY II
This is my first post, so excuse me if it's been discussed before. I am looking for suggestions on how to convert an older OLYII to electric motor powered. If there is such thing as a conversion "kit" that would be great. If not, what motor, battery and controller would you guys suggest.
Phil
Phil
ME
motor
Try this combo it is great From Hobby Lobby 600-7.2V motoer GR1793 $19.19 Gear drive MJ8063 $29.60 prop GPC14095 $35.20 Or as I did GPC14095B prop blades HLKM0153 middle part HLKMO 0240 adapter 4mm HLKMO300 spinner this saves you about $10 if you get the prop for $35 you have to order a 4mm adapter because the prop comes with a 5mm one use any 7-cell pack 1500-3000 mils the climb rate is about45 degrees with a 1700 7 cell I get about 10 minutes full power I have this in a olyII and an Elipzoid 112" the combo is perfect look up Hobby-Lobby for the info I gave you you wont go wrong
