need help
MO
need help
I got a "Wing-Dragon" last year for Christmas. I have had a lot of crashes (most of pilot errors but also some to technical problems. I Am having a lot of trouble with every thing ringht now!!!!!! The landing gear is a piece of !@#! and have had meany proublams with that. On the push rods, the clasp broke and the suports holding it in place are broken also. I was wandering if it would be cheaper for me t just buy a diferent plane. Please respnd ASAP!!!!!!!!!!!!!!!!!!!! P.S. some of those crashes have been pretty bad but the fusalage is still good only a few dents.
RE: need help
The slow stick by gws is a great airplane that has a large wing and is predictable. This is a three channel airplane that uses throttle, rudder, and elevator. This airplane is great for beginners because it will help build confidence and skill. The plane is cheap $35.00 and the parts are quit cheap. Good luck
Bevo
Bevo
RE: need help
I think that plane is same as a BeginAir. The parts you need are only $6.30 and if you need new landing gear its $6.40. Heres a link, click on beginair then spare parts.
http://www.parkflyers.com/
PA
RE: need help
ORIGINAL: jjflash
