props vs motors
props vs motors
Can someone direct me to a side or give me info of how to find the right prop for the right motor ie brushless motor of a specific power what kind of prop goes with it with or without gearbox and what are the best compinations etc.
Thank u
Thank u
NY
My Feedback: (21)
RE: props vs motors
P-Calc does allow you to TRY different combinations of battery, motor, gearbox and prop. It doesn't tell you what will work, so unless you have a reasonable starting point, it's of limited usefulness.
Most manufacturers give you clues as to a range of props and batteries to work with. Some go as far as presenting extensive application tables that show the performance of the motor with many different props and batteries. Personally, I wish more manufacturers produced application tables. It would make things so much easier.
