Anyone using these Servos?
RE: Anyone using these Servos?
They look just like the servos that Interflite makes. The servos are really lite weight but they have a problem centering unless you own the Futaba 14MZ. This was the only radio that they actually centered well on. I've used them in shock flyers and they do fine using a JR 8103 radio. Becareful when you glue them to your airplane because the glue can run inside the case and glue the gears together.
Bevo
Bevo
