Formosa stab incidence question
My Feedback: (15)
IL
Hi Guys,
I`m finally getting around to building my GWS Formosa after it has sat in the box a year. There was some warpage issues that I was able to handle, but I noticed that the main wing and stab were not 0 incidence. The factory molded opening in the fuse for the stab was actually -3 degrees( leading edge of stab was -3 down)It did'nt look right to me so I sanded the opening and shimmed the stab so it is 0 incidence with the main wing. Can some of you Formosa owners look at your planes and let me know if your stabs are in-line or off like I just discribed?Maybe this is the reason some people were having trouble trimming their Formosa's?
Regards,
Frank
Regards,
Frank
My Feedback: (21)
RE: Formosa stab incidence question
Normally if the stab is lower than the wing, you'd see some positive incedence built in to counteract the downwash rolling off the top of the wing, "blowing" on the upper surface of the stab, and causing the plane's nose to rise. I'm not sure why negative would be built in, though. IMHO, you won't hurt a thing by setting it to 0.
There are a lot of slanting Formosas on the market...
Just for fun I measured mine (which flies well) and the angles were 0 on the wing when I set the stab as reference/0. I did expect the wing to have 1/2 - 1 positive according to the stab, but it did not...
