Huh??? WeIrD Problem
CA
Huh??? I just took my wattage cessna out to fly and I noticed the motor wouldn't turn off.Then I looked at it, and when I just turn the radio on now the motor keeps on at full throttle. I took it in to look at it and I couldn't see anything wrong. What do you think happened? I'm guessing something wen't wrong with the esc..? I need help quick.......
Thanks!
Thanks!
My Feedback: (21)
RE: Huh??? WeIrD Problem
Definitely call Wattage (Global Hobby Distributors) and describe your problem. They should be able to either send you the replacement part or an entire new plane if the problem appears to be bad enough.
Please, though, don't take this [:@] with you when you call. You're far less likely to have a favorable outcome if you're like this [:@] than if you're like this . No matter what happened, it's not the call-taker's fault that your plane's broken, so don't take it out on them.
