typhoon charger question
CA, AMERICAN SAMOA (USA)
Hey!
I want to charge my other Ni-mh packs with typhoons charger. I don't get it... I wanna charge normal packs, but I don't no what rate should I charge on?
Paul
Paul
My Feedback: (325)
RE: typhoon charger question
If you list the specs on the batt packs (cell size, capacity) then someone can give you the correct rate. There's a wide range of charge rates you can use and most nimh will use up to a 2C rate if they are high current packs and maybe c/4 if they are tiny cells of low quality.
My Feedback: (325)
If it is a large sub C pack then can charge up to 3 amps or even more, but I think it may be a tiny AA pack and if it is then a rate of 1/2 amp may be the max.
