Multiplex Magister too vulnerable?
Having bolted wing and tail on to my Magister for the first time, I'm appalled at how fragile the setup is. I've screwed in the bolts as tight I dare without forcing them, but there's still enough movement in wing and tail to be a worry. Is there any way to make them more secure?
RE: Multiplex Magister too vulnerable?
my magister is perfect.. i ca'd the elevator after bolting and aligning. i won't remove it so why not!! do your bolts pull the wing tight to the saddle? mine can take a good bit of torque on the bolts.. what power are you using??
