speed control
RE: speed control
Is it a brushless ESC?? If it is a standard brushed, it will only have two wires going to the motor, brushless motors require 3 wires.
RE: speed control
ORIGINAL: samsclub
Yes it is a ESC , so what speed control would you recommend?
RE: speed control
That motor is rated at 8 AMPs continous, 13 Amps MAX, so the E-flite V2 20 AMP brushless controller SHOULD be a plug and play controller (no soldering except for maybe the battery connector). It looks like they connect with 3.5mm bullet connectors, male on the motor, female on the ESC. Ask the vendor before you purchase though as specs change without notice.
Other ESCs would work too, (Castle Creations Thunderbird 18 or other imported brands), but if you go with name brand, it's easier to ask for help and get service if you are having trouble setting it up.
