For Any Slow Stick Owners
i just got one ,and picked up 2 nano servos,Can i use a Electrifly C-30 ESC?from great planes,also can i use a non mini receiver?thanks for any replys
Re: For Any Slow Stick Owners
Always remember with electrics......Weight is your enemy!
i will be useing high speed nano servos to save the weight of 2 standerd servos,these nano servos are real small ,plus iam mounting a AIPTEK 1.3 mega cam,so i guess i will go with a small rx, thanks
Latch66 is right any added weight is bad, but for the Slow Stick you will be fine. It can carry the extra load OK. I have used a standard receiver and standard servos in that plane just fine. The camera adds more weight, so don't push it any further...
mike
mike
I also agree that the Slow Stick can carry the extra weight. It probably isn't the best equipment choice, but it has the power and a large wing surface to stay in flight. I know where you are coming from, any way I can save money, I'll give it a try!
Good luck,
Mike
Good luck,
Mike
flite report= the slow stick flys good,i removed the case of the rx,to save some weight,made a battery pack with 5 AA 1100mha cells, doing take offs from drive way,fun plane, thanks all for the info.now iam looking for new foam tires,props,motors,..i cant keep anything stock for long.
OK
I use a 30 amp ESC and JR R700 reciever on mine no problem. I've even flown it in 20 mph wind gusts, not a lot of fun, but it is pretty stable.
I would suggets using a balsa stick in the fuse tube to add strength. Makes it about impossible to bend even if you auger it in.
well the other day my slow stick had a tree jump in front of it,i lost my prop,drive shaft,any good sites to get SS parts?
What is the best battery for the slow stick? How long will it fly?My 1300 ma Li ion last about 12 minutes, then cuts off. Thanks for any advise,
John
John
AZ
I like the 7 and 8 cell 1100 Mah NiMHs from www.bydusa.com. I get at least 15 minutes on those batteries, usually more. And in the case of the Slow Stick you can definitely use regular sized gear.
AZ
Well I just saw that www.bydusa.com is no longer operating. Bummer! The 2/3A 1100 7 cell for $12.50 and 8 cell for $15 were great deals. www.allerc.com has a lot of GWS parts and batteries for good prices.
