Motocalc for brushless setup wanted please
Hi can anyone please help me out, i have an older sensored brushless motor (Aveox 1114/4y) which i hope to run on a Zagi and i need the motocalc figures for amps etc. Here are the motor specs and it will be running of seven cells 1700 scr turning either a 5x5 or 4.75x4.75 prop, any help greatly appreciated,,,,,,,,,Neal
The Aveox 1114/4Y motor has been discontinued. However, here are the motor constants for those of you with them, or if you wish to compare them to the new motors.
Specifications:
Kv 2743 rpm/volt
Io 1.5 A
Rm .040 ohms
6-14 cells
40A
Dimensions;
1.096 Diameter,
2.5" long without shaft,
5 oz.
4-40 screws on .8" centers
1/8" shaft
Specifications:
Kv 2743 rpm/volt
Io 1.5 A
Rm .040 ohms
6-14 cells
40A
Dimensions;
1.096 Diameter,
5 oz.
1/8" shaft
NJ
Doesn't look promising.. With 7 cells and that small prop you are not getting much efficiency out of that motor and only 11 oz of thrust (same as speed-400)
In-Flight Analysis - Untitled
Sea Level, 68°F
Motor: Aveox 1114/4Y; 2743rpm/V; 0.04 Ohms; 1.5A idle.
Battery: Sanyo 1700SCR; 7 cells; 1700mAh @ 1.2V; 0.004 Ohms/cell.
Speed Control: Generic Brushless ESC; 0.006 Ohms; High rate.
Drive System: 5x5 (Pconst=1.11; Tconst=1) direct drive.
AirSpd Batt Motor Motor Input Output Loss Temp Motor Elect Prop Thrust PSpd Prop Total Time
(mph) Amps Amps Volts (W) (W) (W) (°F) Ef(%) Ef(%) RPM (oz) (mph) Ef(%) Ef(%) (m:s)
0.0 15.5 15.5 7.9 122.1 100.6 21.5 118.2 82.4 77.3 19706 11.6 93.3 0.0 0.0
20.0 15.9 15.9 7.9 125.1 103.1 22.0 119.5 82.4 77.1 19613 10.7 72.9 25.7 19.8 6:25
30.0 16.2 16.2 7.8 127.5 105.0 22.5 120.5 82.4 77.0 19538 10.3 62.5 36.4 28.0 6:17
A 6x4 looks better to me
Drive System: 6x4 (Pconst=1.11; Tconst=1) direct drive.
0.0 21.5 21.5 7.7 165.0 133.5 31.5 141.7 80.9 73.8 18291 19.0 69.3 0.0 0.0 4:44
20.0 21.7 21.7 7.7 166.6 134.6 32.0 142.9 80.8 73.7 18234 16.4 49.1 30.2 22.3 4:41
30.0 21.5 21.5 7.7 165.0 133.5 31.5 141.7 80.9 73.8 18291 14.9 39.3 41.4 30.6 4:44
Sea Level, 68°F
thanks Boomzilla
Cheers for taking time to do the calculations for me Boomzilla, i guess i will try the 6x4 , i was just worried that the amps might exceed the 35amp (60amp peak 10secs) of my Ez30 esc. But i see with the 6x4 its coming in at under 25....cheers
