GWS ICS 50 - Help!
GWS ICS 50 - Help!
Due to mid-air with another mini-ifo, my servo connector wires came off the controller at the pc board. Now I can see where they need to be soldered, but I need to know the order to solder the red, white, black on the board. Can anyone look at theirs?
OH
GWS ICS 50 - Help!
I'm looking at my ICS 50E here. They should have the same wiring config. As you're looking at the GWS label (so it's facing you)on the speed controller, the servo wires go white, red, black from BOTTOM to TOP. Hope this helps.
