what to do with some extra stuff
CO
hey, guys
I had a great planes flatouts reflection biplane. to make a long story short, it's life is over. I diddnt like how it assembled, I diddnt like how it flew, and I diddn't like how it seemed to fall apart.
anyways, I have all the equpment form this plane ( 22m-1000 brushless motor, 10 amp esc, and 11.1v 1300mah lipo battery)
do any of you know of any planes that I could drop this setup into? If not, are there any that would use most of this setup.
I like areobatic airplanes, sport planes, just about anything actually.....
Thanks in advance.
Thanks in advance.
RE: what to do with some extra stuff
you'll probably be looking for something that has a RTF (AUW) of about 1lb, or maybe just slightly more. If you figure 11A cont on that motor and a 3s lipo, you're figuring about 120w. if you want to do mild to average aerobatics or scale flying you'll need something like 100w/lb just to give you an idea
here is a link to that motor
http://www3.towerhobbies.com/cgi-bin...&I=LXJTU6&P=ML
oh your ESC is only rated at 10A, so it's plenty small for that motor, you might burn it up if you keep 11A going to the motor all the time, a 20A ESC would be better in that case, or set a lower throttle end point and go with something a pound or less.
IL
Hey penguin how's it going? I had basically the same setup as yours ( Rimfire 22m-1000, Bl-8 esc, and a 910 3s lipo) , and I put those components in a MSComposit Unique. I was really satisfied with the plane, its performance, and durability. The link: [link]http://www.Mscompositusa.com[/link] I did have to make my own motor mount, due to the rimfires stupid triangular mount, but it was'nt really a problem. This is only one of many possibilities. Keep searching, and you will find something to use your parts in. Best of luck to you!
Trevor
Trevor
IL
Here's another one- [link]http://www.graysonhobby.com/catalog/product_info.php?cPath=2&products_id=535[/link] I plan to try one of these with that equipment. Take it easy!
Trevor
Trevor
