maximum thrust prop for S400
CA
I'm not up on all the computer calc stuff so I'm wondering what would be the higher thrust prop I could use on a Graupner speed 400 in a pusher configuration. Its on a wattage Raptor and flying a little better than the gearbox set up with the Zagi carbon fiber props but I would like some guidance. Also, I'm using a 15 amp speed controller and 8 cell 800 mah NIMH and 10 cell 800 mah NIMH
Thanks in advance
Thanks in advance
