F27C Stryker - Problem
ON, CANADA
All of the sudden my stryker is not responding to any inputs. When I plug in the battery the first beeps happen but the secondary beep don't sound. When I try to give it any inputs, servos or power, nothing happens. One thing I thought it could be is that just before that happened I plugged in the battery when the transmitter was on but the power was at half throttle. Could that have caused some shut down that needs to be reset or something?
Any ideas or advice would be appreciated.
Thanks !!
Thanks !!
My Feedback: (21)
RE: F27C Stryker - Problem
You may have triggered some sort of programming mode in the ESC. Eflite customer service should be able to help you out either with getting the ESC reprogrammed, or with a replacement.
The manual for the f27c has fairly detailed description on how to program the esc. I believe it can be downloaded if you do not have it. Let me know if you cant find the info and I will try to dig it up for you.
