Servos on ebay
MI
Servos on ebay
Has anybody bought any of the mini and micro servos from ebay user raidentech or linearalgebrapower?
http://cgi.*********/ws/eBayISAPI.dl...&category=2563
I just wondered if they are any good. At $8.95 and $9.95 the price is definitely good.
Rob
Rob
Servos on ebay
I have bought from draganfly rc, (same servoes, different distributor) They are woth the price, I also have hitec HS55's (25 bucks or so) The 9 dollar ones are good for a plane you have little in, such a a HLG or small electric. The gears strip easy, and have decent torque. I bought 4 (2 for me 2 for a buddy) and 2 messed up, so I called the guys up, they sent out new ones free of charge. Highly recomend these guys on customer service
Hope this helps
Hope this helps
NJ
Servos on ebay
I'd be a bit carefull. I bought some of these and the -12 version. They are OK for goofing around, but I wouldn't recommend them for a serious plane. The -09s have a really wide "dead band" and thus have a very jerky action. The -12s work like most other servos, except I had one fail on me. Turned out the contol horn screw was too long. When I tightend it down, it pushed the shaft out the other end of the head gear. This shaft is what gives the position feed-back to the motor controller. The result was that the trim kept drifting and then eventually the servo pegged to one end buzzing until I removed power.
MI
Servos on ebay
BoomZilla, thanks. I was just going to use them in an experiment to try to put a "real" radio in my beat up Aerobird and swap the V tail for conventional rudder/ elevator.
Rob
Rob
