Top Flite Cessna 182
FL
Hi,
For a while, I have a Top Flite Cessna 182 stacked away, waiting to be build.
The Cessna is designed for a .61 to a .90. I was planning on putting a .61 in it, because I want to build, and fly it as scale like as possible, and not overpower it.
However, I really would like to put an electric motor in it. So I need a motor, gear???, propeller, ESC, and batteries. Brushless???? What is the best I can get these days to replace an OS .61? Any positive input would be really appreciated.
Wingspan: 81"
Wing Area: 906 sq in
Weight: 10-11lb
Patrick Saenen
Wingspan: 81"
Weight: 10-11lb
Patrick Saenen
I'd take a look at the Hacker B50 XL series of motors, running 20-24 cells. I don't know the exact motor wind you'd want, you might call up Hacker Brushless USA and see what input they have.
Another option would be the Maxcim brushless motors, for 20-24 cells.
--Paul
--Paul
CT
Pat here's my imput,First look over the kit.Remove and replace any heavy wood.Electric's don't viberate.Second my to choices for power are,www.maxcim.com or www.modelairtech.com Nice thing about either set up is that you can change gear ratio at the feild to fine tune prop selection. have fun,stefanP
P.S.Hi Paul
P.S.Hi Paul
