Radio (set-up) woes
Radio (set-up) woes
I am finalizing my Cularis in anticipation of Spring.
I thought sure this would be no big deal (or at least possible with due diligence), but I cannot get the set-up of my Futaba 7CAP correct for a four servo wing—with variable CROW and elevator mix on the VR knob. I’m not sure if I’m plugged into the right channels, or don’t understand the mixes, or just what the issue is (PARAMS, PMIX…).
I think it was WattFlier that had an exact set-up, but I cannot get the flaps working correctly as they described and though I’ve nearly read the letters off the manual, I’m not getting it from that either.
Perhaps someone with a 7CAP can enlighten me (Raileron in channel 1, Rflap in channel 5… A. Brake ON… etcera)?
Many thanks and may the thermal find you with a fresh battery and a free hour...
Mark
Mark
