How to replace an NI-MH with a LiPo battery?
Hi all,
I have bought an F4U Corsair electric plane, that is powered by a brushed 370A motor with gearbox and an Ni-MH 8.4V-650mAh battery.
I am happy with the motor (yes, I enjoy slow flying!) and so I only want to replace the battery for longer flight times.
So my question is, what LiPo should I use for this brushed motor in order to have long flight times and not to burn the motor?
Thank you for any answers!
RE: How to replace an NI-MH with a LiPo battery?
If that can help, here is the complete profile for the plane where I want to use LiPo:
Motor : 370A with gearbox
Propeller : 9 X 7
Power System : GL-370/DS (1:5.3)
Battery : 9.6V NiMh 650mAh
Propeller : 9 X 7
You'll probably want a 2-cell lipo. The nominal voltage of a 2-cell lipo is 7.4V, but the fully-charged voltage is 8.4V.
To get more flight time, choose a battery with a larger capacity (mAh) than the one you are now using. For example, a 1200 mAh 2-cell lipo will be lighter than your current NiMH pack, so you get a double benefit: more capacity and lighter weight.
You'll also need a battery charger that can handle lipos.
- Jeff
- Jeff
