Wireing of 123 cells
I have 4 - 2300Ma 123 cells that are connected by means of a MEC Solderless power tube. I wish to charge them by using my FMA 10 s charger. I thought I could do so by chargeing through the discharge wires, not so must have a node connector wired to pack. Don't know how to wire this node to pack in order to do so. Since this a solderless tube that cells are installed in I wonder how to make a connection between cells? Can I solder directly to the terminals of the cells without destroying the cell? Or should I just place the bare end of wire between each cell? My concern is being sure I have good contact between each cell to provide the total voltage desired 13.2 volts.
RE: Wireing of 123 cells
Thank you Red. I was considering just that myself. I have read many of your replies to others and consider your remarks very interesting as well as helpful.
