Newbie ESC question...
IN
I'm thinking of switching to a brushless motor and ESC on my Super Sportster EP.
Some of the ESC's don't have an on/off switch. They say they have a BEC - (battery eliminator circut).
Does the BEC also eliminate the need for an on/off switch?
Will I need to install an on/off switch or will it just power up OK after the battery is plugged in and I move the throttle back and forth to activate the motor?
Thanks!
Thanks!
PA
RE: Newbie ESC question...
The BEC function has nothing to do with any switches. It is a power supply for the receiver and a voltage cutoff for when the pack runs down. Some ESCs do come with a small switch and some do not. You will not add any switches to an ESC on your own. Once the pack is plugged in your power system is "live" and opening the throttle will then start the motor.
My brushless ESC didn't have a switch, so I installed one in the power leads for just a little extra control. It's easier if I'm flying multiple flights on one battery, cuts the battery drain while I'm waiting to fly, and provides a bit more arming protection. It's also probably a cleaner, more jitter-free power-on for the ESC.
NC
Will adding an on/off switch between the ESC and receiver on the red wire remove all drain from the battery?
This sounds like a good idea when using the same battery for multiple flights to save the battery while the plane is on the ground and not have to pull the Deans plug all the time.
ORIGINAL: Sir Raleigh
NC
Even 20 ma isn't all that much.
I'll put the switch I have in line between the ESC and receiver and then check the current at the Deans plug.
At least with a switch there it will disable the receiver and not allow the plane to zoom off into the wild blue yonder if someone else is on the same channel I am...
