Deuces Wild advice
RE: Deuces Wild advice
Iappreciate all the help. Now that you explaned the numbers it makes sence (I was a toolmaker for 17 yrs). I looked at the Master Air Screw site and believe I seen what I need (appreaciate that dave) Now the problem is choosing the right size, any suggestions? I have an e-mail into MAS. for their best suggestion. Thanks again and good flying to ya.
What is the Kv of your motor and what voltage are you using?
To maximize: 160,000/Kv/Volts=Prop Diameter in Inches
(160,000RPM In) / (650RPM/Volt) / 24V = 10.25 inches
160,000 is the max rpm inches from Master airscrew.
axi recommends 14x8 props with that motor, what made you decide to go with the 9x6 props. trying to learn about props and how to choose the best ones for my deuce.
