Parkzone Li-Po charger?
CA
Im new to Li-Po and i just got the parkzone 2-3 cell Li-Po charger. I dont know what setting to put my charger on. I have a 3 cell 11.1V 1800mAh battery.
The charger can be set to:
.3
.5
1
1.5
1.75
2
The ironic thing is that there is a warning that the divise could catch fire if set past 1 amp
Thanks for all the help!
.3
.5
1
1.5
1.75
2
My Feedback: (14)
AL
RE: Parkzone Li-Po charger?
First... do not charge unless you are in the same room watching the battery...
Second.... Have the battery in a fire proof container so flames can not start a fire...
Third... Be careful... set the charger at a setting less than your battery size... maybe a 1800, 2100 or 2200 size, 3 cell..
I would set the charge rate at 1.5 for a 1800 size battery but you can go to 1.8... just be careful and keep an eye on the battery during charging...
PA
ORIGINAL: tiggerracing
.3
.5
1
1.5
1.75
2
.3
.5
1
1.5
1.75
2
