GWS Tiger Moth 400 question
Is the GWS Tiger Moth 400 from http://microrcflyer.com/airplane.htm the kit? Im not sure if it is. All that it says is it comes with the 400 motor. If this is not a good site to buy from please tell me where I can get this model. Are all the other GWS models on that site kits too? TIA
-cade-
-cade-
RE: GWS Tiger Moth 400 question
As far as I know the Tiger Moth is only available as a kit. But it is a pretty easy kit. You don't actually build the wings or the fuselage you just join a couple of large molded pieces. I consider GWS foam its as "semi-ARFs". In the typical wood kit you have to build the wing and the fuselage which is a LOT more time and effort.
Try it, you'll like it!
ORIGINAL: outpost
-cade-
-cade-
It goes together very easy, the instructions are not the best, but there is a Greg Convey report on the building of this kit here in Rcuniverse that is very helpful (if you need help). I will have mine ready this weekened but it might not maiden until the weather improves... I just needed something to play with at a pond:-)
All you will need are the servos, a controller and a reciever. I am using a Hitec 555 receiver and Hitec servos (HS-55), I purchased a GWS controller and a 1320 lithium battery. You get the motor, a gear reduction, the prop and even a tube of glue. I used 5' epoxy in most cases, and I used the glue provided for the hinges...
Good luck!
Gerry
Note that GWS glue is excellent but there are no instructions. This is contact cement. You spread it on both surfaces, then give it 15 seconds to a minute to set. Then join the parts. The longer it sets the faster it grabs. So if you have to slide the parts together, a shorter set is better. If you use it like regular white glue it can take hours to set.
Epoxy, white and yellow glue or foam save CA will work too.
ORIGINAL: aeajr
Gerry
