esc for 1530 kv brushless motor
hi guy's newbie flyer i have a skyartec 1530 kv brushless motor should i get the skyartec 18 amp brushless esc or is there a better alternative i'm using a 15 c continuous 20 c burst 11.1v 1100mah lipo is an 18 amp esc big enough please help
RE: esc for 1530 kv brushless motor
Beanie ... it depends on the prop now that you have decided its a 3S pack. Too large a prop and the motor will draw tons of amps. What prop will you be using?
Did you get the motor from the Cessna? If so it should be around an 8x6 but best to get a watt meter so you know how much is being drawn. Its a great investment to ensure you do not mess things up. If not just get a 25A ESC, it will suit a lot of aerobatic planes of about 40" wing span.
