Parkzone Micro 210 Centurion
CA
I have flown this lil guy for a while, crashed nose first after dislodging plane from a tree, prop shaft snapped, but I finally fixed that, now when I plug in battery, there is a constant beep with no connection to the transmitter. Any Ideas?
CA
RE: Parkzone Micro 210 Centurion
Well, I plugged in the battery to the plane, it had a continuous beep and would not stop. Turns out I had an extra transmitter from parkzone I got confused and swapped the other transmitter, so I guess that beep was the "not binded to this transmitter warning". Long story short, I was trying to fly with the wrong transmitter, and eventually found my binded one to that airplane. I know you can bind those transmitters to the planes by holding one on the sticks in for like 5 seconds, but no need this time!!
