Motor fried up
FL
Motor fried up
For some reason, my stock SIG EP-42 brushed speed 400 motor started to smoke and eventually seized up while I was running a bench test of the battery. It ran about six minutes at 3/4 throttle or so before I started to smell the smoke and shut it down. I was using the stock 30amp speed controller and a 2000mah 8.4v NiMH battery.
So, I guess the brushless conversion is going to come faster than I'd planned. I am looking for a quality motor that will fit under the cowling. Are there any that are direct fits? IOW, that I can just mount up to the existing heat sink and existing mounting holes? I'd like to have plenty of power so that I can use the motor in other airplanes down the road. This EP-42 is an eyesore thats already pretty rough. Its in flyable condition, but anything I buy for it will likely be switched to something else down the road.
I am completely new to electrics - so I'll need a good esc recommendation too.
Any ideas what happened with the old motor?
RE: Motor fried up
Hi
I am fairly new too, but Iseem to recall someoneposting that you shouldn'trun your motor on the bench unloaded. I think the result of doing this is exactly what happened to yours. I could be wrong, could anyone else confirm this?
Con244
Con244
FL
RE: Motor fried up
Hey Bryan,
What you did was cook the motor. Electric motors should only be run static for long enough to get a meter reading. What happens is the motor is getting little to no cooling airflow sitting still. Yeah I know you had a prop on it, but the center of a prop is where the least amount of airflow is produced, right where the motor sits.
Ditto the esc, you can burn them up without airflow, and you could in the right conditions even damage a pack that way.
I see you are a member of Imperial, me too.
Looks like we get a no fly today with the Pres in town.
If you need help, PM me and we can hook up. I can give you my cell or meet you at the field.
Brad
Hmmm, I just looked up your bird. According to the review they come with brushless motors, is yours an older version?
If you can post up the spec of the motor you have it will be easy enough to get you hooked up with a good brushless set up, and maybe even talk you into a lipo system.
Brad
FL
RE: Motor fried up
Here you go.
Motor http://www.hobbycity.com/hobbycity/s..._1000kv_/_180W
ESC http://www.hobbycity.com/hobbycity/s...eed_Controller
Pack http://www.hobbycity.com/hobbycity/s...00mAh_3S1P_15C
9x6 APCe
11.36v
13.8A
157W
8580rpm
25 oz thrust
If you don't want to remove the stock mount, it's easy enough to convert it to an outrunner one, here's how I did my P-38.
9x6 APCe
11.36v
13.8A
157W
8580rpm
25 oz thrust
FL
RE: Motor fried up
Glacier,
I used to be a member of imperial, but its been a while since I've been out there. Actually, I am currently flying on a private piece of land owned by a friend who is also into RC. He doesn't have a paved strip, but the lot is large and remote and allows us to do whatever we want without bothering anyone. He's been working as an instructor to me too as I've just come back from a several year break. I am going to rejoin with imperial at some point, I am sure.
I got a recommendation from Lipopilot (at wattflyer) to go with this:
http://www.headsuprc.com/servlet/the...ushless/Detail
http://www.headsuprc.com/servlet/the...R-UP20A/Detail
I picked up a 3 cell 1500mah LIPO and some 8x6 props. It probably won't be too over powered, but should outperform the old stuff with no issue.
I bought this thing a long time ago before the brushless version came out.
FL
RE: Motor fried up
Ah yes, we call the 2822 the famous $6.00 motor. Great little motor. Check shipping from the site you were given and Hobby King's, as stated the motor is $6.00(actually $5.95) from HK. http://www.hobbycity.com/hobbycity/s...idProduct=5354
FL
RE: Motor fried up
After crunching the numbers, my order would have been cheaper through HK than through heads up RC. Oh well. In fact, I could have gotten an extra Lipo battery for the same price as I paid for just one along with the other stuff.
It seems that that motor would be a bit too small for a SIG EP-42. I don't doubt it'll fly ok, but most people seem to use it for foamies. The EP-42 is a built up balsa airplane with a 42" wingspan.
