Motor
AZ
Motor
Can i use this motor (http://www.hobbypartz.com/75m15-opti...12-1200kv.html) with my factory ESC 15-20A and 2S 1000mah Batteries insted of this motor http://www.hobbypartz.com/93a260-09-brushlessmotor.html. the reason whyi want to upgrade or changeis because they no have the factory one in stock.... i wonder is this motor would do it ???
FL
RE: Motor
Would be close. Little less kv's so you may see a slight drop in performance. Also the mounting is different. The Optima uses an X mount vs the style used on the other.
If you can mount it it should be fine. I have 4 of the Optima motors, different type, but they perform quite well.
