Duralite 4300 Problem
Dears,
I have a Duralite Li-Ion 2s2p 7.4V 4300 mah with the Duralite regulator placed on my N9 Synergy Heli, the problem is that after charging the battery it reads 8.3V with no load and goes down to 7.5V with 1amp load, is that normal or does it mean that the battery needs to be replaced?
Also what is the best charging mah? do you have any charging tips?
