matching components
matching components
Hello all,
I am in the process of attempting to salvage parts from a number of different old friends to put into a new one. The new plane comes equipped with a Tower Pro 21 Outrunner motor. The specs say I need:
- [*]Micro receiver
[*](2) Mini servos -BMS 380MG recommended
[*]2-3 cell 1200-1500 LiPoly
[*]18 amp Brushless ESC[/list]What I have in my collection of parts is as follows:
- [*]PKZ1814 18A Brushless ESC 3s 11.1 LiPo[*]2 Parkzone DSV130M servos[*]Spektrum AR6110e receiver[*]Spektrum AR500 receiver[/list]And as far as batteries are concerned, I have a couple of 2S 1300 mah batteries and 3S 2200 mah. I am planning to use the 2S batteries to start but curious if there's any reason the bigger 3S can't work.
Any other red flags here? Will the PKZ1814 work ok with the 7.4V battery?? Any reason the AR6110e won't be adequate as well? Any general guidance on how to select components that will be compatible is appreciated. Thanks.
