Help setting up Dx6i Delta Wing
Hi guys,
I just recently got a Hobbyking Jetiger, similar to a PZ Stryker. My question is how to set up y Dx6i radio to use it with the Jetiger. I am new to the Delta wing world, to I need to use the elevon setting or the D-wing setting? Where does each servo plug in? Left aileron to aileron port and right aileron to elevator port?
How do these work? I want to know its setup properly, if I want to go up and right how would the control surfaces look? Both ailerons up but the right one being higher than the left?
Thanks guys
Thanks guys
My Feedback: (9)
RE: Help setting up Dx6i Delta Wing
I've never understood the difference between "elevon" and "delta" set-ups. All my wings and deltas use the "elevon" setting. Plug one servo into the aileron port; the other into the elevator port. If controls are on the wrong stick switch ports. If they are reversed follow the usual directional adjustment procedure. Most of these things need a couple of degrees of "up" at neutral. Yes, when going up and right both elevons will be up, one more than the other.
walt
walt
