A Hot Speed 480?
A Hot Speed 480?
After I get done charging my 1400 nicad 8cell and hooking it up my motor won't run. It seems like I have to wait 2 min. then give it throttle and it works. Is that normal? Is it getting over heated?
A Hot Speed 480?
Kyle,
No, that is not normal. Perhaps you are not setting the ESC's safety arming procedure. Some ESCs require 3 seconds off throttle and then 3 seconds full throttle after a power-up. When you return from full throttle back to off throttle, the motor is then enabled.
