Needing help on Hitech Aurora 9 differential thrust
Howdy all,
I am building a FT Kraken and using a Hitech Aurora 9 radio. I need help on setting the radio up for differential thrust (twin motor). There is little info or videos on how to set the xmitter up for such. I need detailed instructions, videos, or pictures due to I am new to this radio. Any help is greatly appreciated. John |
With the number of rudderless, twin engine aircraft available you would think the radio manufacturers would be clamoring at the door to be the first to offer this capability as a standard mode. It goes right along with V-Tail and elevon mixing.
I see that the Kracken is a rudder-less wing. This should give you what you need, but don't make the rates too high, or your plane will dive when you bank it into a turn.
You need to put the throttles on different channels, and you will use three separate mixes. 1-Mix the two throttle channels to work together on the throttle stick. Set this mix to be on all the time. 2-Mix the left throttle to the aileron stick. Set it to accelerate with right aileron and decelerate with left aileron. 3-Mix the right throttle to the aileron stick. Set it to accelerate with left aileron and decelerate with right aileron. Set the mix rate on 2 and 3 to about 20% to start and adjust as needed. I would be a good idea to put mix 2 and 3 on a switch in case you need to cancel it in flight. If your airplane had a rudder, these instructions would be different. |
