Models for AR6400L
1 Post
Models for AR6400L
Well I got the AR6400L and I am looking for a slow and easy to fly model to build. I Got some contest grade 1/32 wood here that seems could be use.
Does anyone has some plans to share?
I got 2 of this motor that come from one of those micro models tower hobbies use to sell which had only power control.
If get the proper connector would it work with the Spektrum AR6400L?
Are there servos other then Spektrum that works with AR6400L?
Thank you,
Martin
Thank you,
Martin
My Feedback: (81)
VA
RE: Models for AR6400L
Here are some compatible servos for you. Someone else may help with plans.
V tail set up
http://www.hobbycity.com/hobbyking/s...dProduct=10706
left
http://www.hobbycity.com/hobbyking/s...dProduct=11737
right
http://www.hobbycity.com/hobbyking/s...dProduct=11735
V tail set up
left
right
