Cool New EPP Dualsky Breeze Mini
NC
Small, Light and durable. These features make the Breeze Mini a great indoor plane. This indoor aerobatic 3D airplane is made of EPP, a flexible yet light weight material. This model is an excellent choice for high performance aerobatics.
Breeze Mini is designed by a professional pilot from the Dualsky team. It excels with unmatched flight characteristics and high flying performance. Stability is a key characteristic built into the plane to allow many different amazing 3D and pattern maneuvers.
When building this model, please use the lightest components available for the best performance!
Specs:
Wingspan: 620mm (24.4in)
Fuselage length: 656mm (25.8in)
Flying weight: 75g-85g (2.6- 3oz)
Motor: Dualsky XM1812-42
Propeller: GWS 6x3
ESC: Dualsky 6A
Battery: Dualsky 7.4V 150 mAh Li-Poly
Servo: 2.5, 3pcs
Specs:
Propeller: GWS 6x3
ESC: Dualsky 6A
Servo: 2.5, 3pcs
