please help with mingji 2.4ghz f-series 4 channel helicopter
MA
i just bought this heli and found that on the left stick on the remote that i have throttle and side to side flight control.But on the right stick i have forward and reverse flight control and left and right turning control.Now i am used to having the throttle and the rudder on the same stick on the left side of the radio.The right stick always has the forward and reverse and the aileron control.Is the any way to fix this.Also the manual states that joystick functions can be devided into accelerator side flight and accelerator turning.......but does not tell me how
ON, CANADA
RE: please help with mingji 2.4ghz f-series 4 channel helicopter
You have a mode 3 Transmitter for the helicopter. What you want is a mode 2 Tx.
Do you have a mode 2 2.4ghz Tx? I don't think the binding protocol is the same.
Hope that helps
JSS4
Hope that helps
JSS4
